Wish: "Connect" to have a RMB version with smooth extensions that preserve the structure of the curves
Since Rhino 7 has a great ! _ExtendDynamic _Pause _Type=_Natural command that does not add extra control points and preserves the structure of the extended curve, why does the ! _Connect command with the “ExtendOtherCurvesBy=Smooth” option change the structure of the input curves by adding extra an control point to each of them? Is not it more natural for the ! _Connect command to use the same approach as the ! _ExtendDynamic _Pause _Type=_Natural command? :slight_smile:
Original curves:
Extend natural preserves the structure of the curves:
Trimming of the extended curves preserves their structure:
Connect with the “Smooth” option destroys the curve structure by adding an extra control point on each:
Fully agree. Would avoid lots of issues that can occur due to too many control points. Especially when the extension is short.
Thanks, added as
RH-63393 Connect with ‘Natural’ extension
Awesome! :slight_smile: Thanks!
Yes please! Perhaps Extrude tapered could benefit from at least some of the same logic too.
This works now after the latest update. Thanks to the “McNeel” staff! :slight_smile:
