WISH: Command: '_Zoom to not count as part of command History?
Would it be possible to have _Zoom (shortcut ‘Z’) to no be part of the command History?
So the same way one can orbit around and zoom in with scroll wheel and not get that into command history, can we have Zoom not be part of it?
I often use Spacebar to repeat commands such as move, and Zoom always breaks my workflow because when I press Spacebar it prompts again to Zoom a region.
It’s not. It’s part of UndoView and RedoView.
You are right. I actually mean something different, will edit title.
What I mean is not be part of history at all, for instance:
I am moving points, and pressing Spacebar to repeat command.
I need to zoom in, so I press Z and windows select, but then I press Spacebar to repeat command and I am prompted for window select region to Zoom in again.
You can always Add Zoom to the “Never repeat these commands” list in Options > General
Awesome! At first it did not work because I tried Zoom and '_Zoom
But inputting only ‘Z’ made the trick. Thank you!
