WISH: Color transparency only affecting surfaces, not edges
I think I saw a similar wish, but I can’t find it right now, please merge it if you will find this thread.
I can’t find the setting to make my semi-transparent objects appear in the desired way.
I would like to tweak layer color transparency without affecting the surface edge’s color, they should still resemble the layer’s color, but shouldn’t be washed out with the transparency increase.
Maybe the toggle would be enough, or some multiplier.
Desired appearance
Added a feature request RH-81435
