WISH: Change opacity of multiple different color layers
I would be quite practical to be able to change the opacity of multiple layers at the same time while conserving original RGB values of each.
Thanks
You could do this with Grasshopper and Elefront or scripting.
modify_layer.gh (7.0 KB)
Cool, will probably create some Elefront def template for future use. Still it is quite a basic feature that should have been available from the get-go of opacity introduction to layers.
Ah thanks for the def!
It’s a basic definition and if you wanted to change just the opacity I think I’d use a Create Material component which has a separate input for the transparency.
