(wish / bug) precision for _radius _length _distance
_radius
_diameter
_distance
_length
can be used to query a number from existing geometry - and use it as input.
it feels like you get precise input - but there is a hidden trap for (precision)-errors:
it looks like the generated input depends on document tolerance.
example:
draw a circle with
center = 0
radius = 10.123123123
now draw a second circle
center = 25,0
radius = _radius (and click the first circle)
increase documentproperties units display precision to maximum
_radius of first circle
10.12312312
_radius of 2nd
10.12300000
so the digits beyond units display precision is lost.
wish:
the commands should check wether they are nested - and if so the output should be maximum precision (12-16 digits ?)
only if they are not nested, a pure rounded within display precision output / info is ok.
would be nice to show the rounding like
10.123 (rounded)
10.123 …
or similar
if i enter a formula for a length
sqrt(2)*20
the result in geometry is precise
hope this explains my concerns.
thanks for having a look
kind regards - tom
Got it - https://mcneel.myjetbrains.com/youtrack/issue/RH-99645
– Dale
RH-99645 is fixed in Rhino 9 Service Release 1
