I’ve noticed that different windows/panels use different check boxes (black check mark on white background, black dot on white background, white check mark on blue background, and white dot on blue background). It would nice with some visual consistency, preferably the black on white ones:
Well, I think the difference between the “checkboxes” and the “radio buttons” (dots) is that the radio buttons are used when there is a mutually exclusive “either-or” type of situation, and checkboxes are used when there are multiple options that can be chosen independently. I think that’s not a bad way to distinguish between the two different scenarios.
That still leaves the difference between the black and white and blue and white versions, not sure what the philosophy is behind that.
The shift to blue is part of an attempt to follow Microsoft’s style over substance Windows restyling. Just not universally applied yet. And strictly, it’s blue when on and black when off. as seen above.
I think the shift is actually the other way… I looked at V5 and the checkboxes are pretty much ALL blue when active and white/gray when not. V6 as well. It’s only in V7 that some of the dialogs started having black and white checkboxes.
