Hi…,
it would be nice, if “_blend _perpendicular” could work with object snapping for the second point, perpendicular object snapping would be good.
Thanks
Michael
www.flexiCAD.com
Hi…,
Thanks
Michael
www.flexiCAD.com
Hi Michael - You can trick it with the Point Osnap - if you find the first point location on the first curve with Point then it will be at the closest point.
Hi Pascal,
I don’t get it. Do you have a video for me?
Thanks
Michael
Hi Michael - it is a bit hidden… and I am not sure this is what you are after but have a look here:
this also works on ‘Add Slash’ inside Sweep2
and adding shapes in BlendSrf
, which is handy.
Hi Pascal,
now I see it. I still have a lot to learn.
Thanks and a sunny weekend
Michael
