I primarily work in perspective view, and one thing I’ve seen in other modeling packages (such as modo) that is a HUGE help when working in perspective is a Cplane that auto updates to the approx view at any given time. So, as you say get close to a top view, the cplane automatically toggles to the top view. It’s a pretty simple thing, but man does it really speed things up when working in perspective view. Pretty please?
If you install the script (directions here- http://wiki.mcneel.com/people/pascalgolay) and add WorldCPlanetoView to an alias or button, it should at least be a one-click change as you need it…
Thanks Pascal! I’ll give that a shot. Thanks for adding that to the pile. It’s a fairly common feature of other packages at this point, and I can definitely see why!
as i can see this is a very old topic but i am now driven by need to have this functionality .
I am using latest RH 7 release and i wonder if there is a way to get a real time update of the construction plane within reference to the perspective view.
BTW assuming this was compatible with RH7 , the below link is not longer working
This was implemented in Rhino 6 with the OneView command.
You can play with the settings, I have OneView 15 MaximizePerspective=No Enter as one of my start-up macros.
