Wish: Added option tolerance in the command "Pipe"
Added the option “tolerance” to the command “Tubing”.
(If you work in 0.001 or 0.05 tubing in certain situations does not work, it must necessarily lower the tolerance, so if there was this option within the command would be more comfortable).
It would be better to know why it fails, this way it would be easier to repair the curve you’re using to create the pipe.
Usually this can be solved by enabling the _FitRail option, if not the curve might be looked at for repair.
c.
