Wish: Add info to Command History for DropFileProxy - Insert file
8.8.24170.13001, 2024-06-18
When I drag and drop a file onto my current document and choose Import file from the File Options dialog box, “Successfully read file” … is stated in the Command History, and DropFileProxy is added to the undo stack (_UndoMultiple).
When I do the same but choose Insert file, nothing is added to the Command History. DropFileProxy is added to the undo stack.
Please add the “Successfully read file” … to the Command History for the latter scenario similar to the former.
Thank you
