I use this configuration for work:
Rhino for Mac 5.1 installed and running on OS X Yosemite 10.10.5 (14F1713)
Parallels VM with Windows 8.1 Pro 64bit installed via bootcamp
MarCom 5.0 Pro software (Windows only) + Mahr measurement tools
My goal is to measure dimensions and have these transferred directly into Rhino (into the active text field while designing).
MarCom does allow to configure a keyboard command output with added functions as or added behind each numerical output.
example: "123.456 "
The data transfer runs like this:
- physically measure a dimension on a work piece with a Mahr caliber
- press a data transmit button on the caliper
- data is received by a Mahr supplied Ant+ USB stick
- data is received by MarCom software and translated into keyboard code
- keyboard code is broadcasted to the OS (result is as typing on the keyboard)
It is mainly designed to be used to output numerical values into an open text or Excel document to create measurement reports.
On the Windows side everything works beautifully (and I am sure if I would use Rhino for Windows, it would work fine).
The issue is that somehow the keyboard commands do not arrive in Rhino when created in the Windows guest system.
I am already in touch with the devs at Parallels who currently are looking into this.
Did anyone do something similar and has probably some ideas involving transferring inter-OS transferred keyboard commands into Rhino - maybe using another virtual machine software?
I am open to any hint to make this work, reason for the dilemma being that unfortunately the measurement software of Mahr is only available for Windows but we run a Mac only environment in our company.
