Is there a way to extract the edges or vertices from a smooth SubD so that I can use them to create a wireframe? Maybe it’s a strange workaround but I like the esthetics of the smooth edges of the SubD and wish to create a separate object from it. I don’t need the surface of the smooth SubD, just the coordinates of the vertices, so that I can create separate curves from them. (hope you understand, not a native speaker) Rhino7 for Mac
Select the object you want in smooth mode and use the command _ExtractWireframe. That will turn the wireframe you see into new curves.
Fantastic and so simple!
