Wirecut issues
Hi I hope that someone can help, I’ve lost a lot of hours trying to get to the bottom of this today.
I resurface scans of wooden turning models in the shoecare industry and have done this exercise hundreds of times. From a laser scan I resurface in Rhino the cut shapes out with the wirecut command.
I upgraded to Rhino 7 last week after being on v5 for ages with no issues.
Hopefully you can see on my first picture the red line which is a simple open curve being used to wirecut from the Front view. All the settings are identical to what I notmally use. However I’m being left with an artefact which is visible in shaded and rendered views but not wireframe.
I dont understand what is going on. I’ve redrawn the cutting shape to make sure that the line is problem free.
Any ideas welcome as I’m pulling my hair out and have deadlines
Systeminfo below
Rhino 7 SR3 2021-2-22 (Rhino 7, 7.3.21053.23031, Git hash:master @ f8a40388712d9cf7edc68910e0415427bdefc64a)
License type: Commercial, build 2021-02-22
License details: Cloud Zoo
Windows 10.0.17134 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [81% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 8-15-2018 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P3200 (NVidia) Memory: 6GB, Driver date: 12-6-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.69
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2020
Driver Version: 27.21.14.5269
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.3.21053.23031
Without seeing the 3dm it just looks like a meshing artifact, not “actually” a problem, changing the display mesh settings will probably make it go away.
Jim you’re a legend. For whatever reason the maximum aspect ratio was set to 6 in V7 but was 0 in V5.
Changing to 0 has fixed it. Thank you very much.
