G’day All,
When wirecutting an object that has a pair of named positions, the named positions still affect the object, but moves it unexpectedly.
If the objects ID is destroyed in a wirecut, then why does the named position still affect it. And if the ID isn’t destroyed/replaced then why would named positions not behave normally.
Aside, FilletEdge doesn’t affect the named positions functionality, probably because the ID isn’t changed.
Original Position 1 (rectangular object on the left)
Position 2 (shift rectangle to the right)
Wirecut in Position 2 (keep all objects)
Result of restoring named position 1 (no change to positions, but expecting rectangle and wirecut circle to go back to the left)
Result of restoring position 2 (shifts object further right)
This probably isn’t possible due to accounting issues with the object ID, but desirable behaviour would be for the objects created after modifying a part that has a named position should retain the original named positions of the original part.
