WIP9: Block Display Changes When Navigating the View
I’d like to report something strange happening in WIP9 when using blocks and block copies. Depending on how you move around the scene, the objects change their display appearance.
I imagine it’s a small glitch that will be fixed soon, right? (Please don’t change the block display behavior from Rhino 8!)
Hi Gianni -
I’m unable to reproduce that behavior here in a similar (?) scene:
2026-01-22 BlockDisplay
Please provide both a 3dm sample file and the output from the Rhino SystemInfo command.
“Hi Wim, thanks for your reply. Here is an image with an example. When working with blocks and block copies, it sometimes happens that some objects become transparent. I’m sending you the file and the systeminfo.
TEST BLOCK.txt (2.3 KB)
test block.3dm (878.2 KB)
