if I open option dialogs like _options tjhan nothing happens because the options are opened in background. I need to click on the Rhino UI and than the option UI is shown. (6.0.16285.11581, 11.10.2016)
Best-
Micha
Best-
Micha
Hi Micha - I do not see that here, so far - do you mean Options opens behind the main window? How are you accessing Options - button, command line, or?
thanks,
From menu, from command line, from toolbar - always it open behind the main window. Maybe it’s caused by a plugin I’m testing. I will observe it in the next time and will write again.
Thanks,
Micha
