If you try the menu item Tools>Toolbar layout you get this:
Odd… command>Toolbar, unknown command >Toolbars
Hi Mitch - that’s not happening here. I’m probably running a slightly newer version but I can’t seem to find a YT item that would have fixed this.
I could try “downdating” to the version that you are running…
Have you double-checked that the Toolbars plug-in is loaded?
Yeah, it was loaded… After a restart it is now behaving correctly. Don’t know what happened there.
However, after having loaded a custom workspace file from V6, I now have the command prompt misbehaving - normally dicked at the bottom, it goes to the top every time I re-open the WIP. Will post a new item for that…
