WIP Export Focus Dialog
Maybe this has always been this way but it feels new to this WIP and off.
I open the export dialog panel.
The filename is highlighted dark blue background white text, type and the name changes, all good as expected.
The filename is highlighted dark blue background white text. I change the filetype in the dropdown selector, choose OBJ from the list (for example). The filename remains highlighted dark blue, however if I then type, it just chooses another file type from a match in the dropdown list.
It feels like when I have picked a file export type, clicked on it with the mouse, that the focus should revert back to the filename input and not further accept key strokes to change file types.
Similar/same issue:
Thanks.
I’ve put this on the list as RH-98515 Export: Do Not Prefill File Name
@nxakt , @phcreates
fwiw, this week’s (*) Beta will have a new advanced setting that allows you to turn off prefilling the name field with the current name of the file. If you often run into the issue that was described, turning off the option might help.
I’m not convinced that’s the ultimate solution for this (and other) issue, so I’m leaving that YT open for the time being.
(*) we have a few stop-ship items on the list today that could possibly delay / postpone releasing a new public Beta.
