WIP Dot command issue
Using the latest WIP, I’m having issues with creating dots from a set of commands. If I paste the following commands into WIP all the dots end up at the origin. In R5 they end up in the right place.
-Dot A 221.99388,810.280116,84.831789
-Dot B 190.920491,807.502502,84.744347
-Dot C 166.223418,811.452301,84.799239
This only seems to effect dots. If I create points using the point command they end up in the right place. As does a polyline through these coordinates using the polyline command.
-Point  221.99388,810.280116,84.831789
-Point  190.920491,807.502502,84.744347
-Point  166.223418,811.452301,84.799239
-Polyline 221.99388,810.280116,84.831789 190.920491,807.502502,84.744347 166.223418,811.452301,84.799239
My only workaround at the moment is to create the dots in R5 and copy/paste them into WIP.
Thanks for the report. I have added to our bug tracking system: RH-42319
I see it; this will be fixed in next week’s WIP. Thanks for reporting the bug.
Thanks, that’s great! :smiley:
RH-42319 is fixed in the latest BETA
Is it possible to introduce the special character set in the “Dot” command? (for example, square root, alpha, beta, infinite symbol, etc.).
Currently you can change the font and size.
It can be done?
