WIP bug_Popup menu command crashes
Hello all,
I just discovered a strange behavior, probably a bug. Whenever I use dupicate edge or duplicate border from my MMB menu, rhino immadiately crashes. But when I use the same commands from the toolbar, it works well..
Didn’t test every command in popup menu but majority are OK
SystemInfo_RhinoWIP.txt (3.4 KB)
in your screenshot you have what looks to be Project Edge, i haven’t been able to duplicate with either with the steps provided.
Sorry, this should explain my problem better
@can.aysan if you do/did send that report I should be able to fix very easily :slight_smile:
Yes I did (yesterday I think) when I first encountered it :+1:
I see it, thanks for reporting!
RH-95175 Pop-up cascade crash
If you’d like to prevent this crash (for now), I think if you turn off FloatToTop for this item it’ll prevent this.
Couldn’t find FloatToTop option on Windows. But I guess I can live with that until next update if this won’t be too long to fix :slightly_smiling_face:
Float To Top is set on the toolbar item itself that you started the cascade with
RH-95175 is fixed in Rhino WIP
