I almost never use icon and mostly work with text command and aliases:
When I type _blockedit, it opens the block editor, but the cursor does not goes into the dialog text box.
So if I type anything right after and press enter, it doesn’t write it, and it runs “add object” command.
Is there a way you can fix this?
Thanks for your work.
Philippe
Hi Pascal, thanks to you!
