I don’t get the ambient color working for the rendered mode. I disabled shadows and “use advance GPU” lighting. Any ideas? Is it a bug?
Ciao,
Micha
Ciao,
Micha
Micha
Ambient is very poorly supported - in fact, just yesterday I removed it from the UI. What do you need it for?
Removed? That’s hard. At my screenshot you can see a part of my train interior scene (I can’t show more). Large areas are black. At v5 I used the ambient color to get a good basic brightness everywhere. I don’t need lighting effects, but I like to see all scene and texture details everywhere.
The ambient color was a great simple basic feature at v5. It doesn’t slow down the UI. (My current display speed of this scene is approx. 1 fps, so I tried to disable all special effects and keep the basic ones only. testmaxspeed -> 148s)
Hi MIcha - does the tone mapping control on the Render window give you the control you need?
Hi Pascal,
I can’t find the tone mapping control, only a gamma option and “use linear workflow”, but it doesn’t affect the viewport. Also the ambient light of the render options doesn’t change anything. I set the ambient light of the render options and the display options at white - no effect. At Rhino 5 I would get an over bright display.
Workaround - I setup a custom lighting.
-Micha
Ah, viewport display not rendering… I got it now. Never mind… Sorry.
