WIP 9 display mode bug
Hi.
I’m testing Rhinoceros 9 Wip version 9.0.25224.18305, 2025-08-12.
I can load custom display mode but when i execute same operaion like “Save as”, delete layer and others it disappeared and I have to reload it.
It never happened with Rhinoceros 8.
Btw: if I open the same file with Rhinoceros 8 the Custom Display Mode appears.
Good work.
s.o.
You mean that you first load a custom display mode, then you do some operation or saving the file, which then deletes the display mode from Rhino 9 WIP? Sounds weird to me…
The display modes are stored inside Rhino. What happens if you open another file with Rhino 9 WIP? Are you still able to use the same custom display mode what was no longer available after saving the initial file?
Hi. It seemed strange to me too.
Now I tried to import the display mode in a new file and I can use it in all the files as normal.
I will let You know if some weird situation happens again. Ty
