Hi @Joshua_Kennedy , Guys,
here’s another couple of suggestion on how the PushPull command should it work, or I think a basic user should expect to behave.
1.the inset command is creating a full offset in a case of cylindrical surface. I think it should result as 2 parallel lines fully turning around (red drawing) I see this is working by extracting Isocrvs but I can’t express any distance value.
1a. could we add an Absolute/proportional option to the Extract Isocurve as well?
- the PushPull itself is extending only straight also when the side surfaces are cilindircal
Thanks to take it in consideration.
