My Rhino 8 was working fine just yesterday. I left my computer on overnight and it mustve crashed as when I opened Rhino this morning it said that Rhino did not close normally… It appears that Windows Security is now blocking specific plug ins in my app and not all the tool bars are loading properly. Is anybody else having this issue? Was there a recent security update?
have you found a solution for this? Having a similar issue
There is a known issue with Windows Smart App Control blocking some plugins because it doesn’t accept their security certificates.
As a temporary measure (or permanent, depending on what you think of Smart App Control) while McNeel work on the certificates, you can turn it off in Windows Settings. Edit: You can turn it off in Win 11, I don’t know if you can in earlier versions.
had the same, indeed Switch the Smart App Control setting to “Off” worked
I y case all toolbars were missing, so for other just, to restore them type in command bar WindowLayout
