Windows 10 freeze rhino 7
Rhino 7 is freezing my machine every on every use requiring a hard reset.
I believe all the system drivers are up to date
Files are on local drive copied by dropbox
turned off GPU tessellation hasn’t made a difference.
Help the software is near unusable at this point … have to save after every successful operation
My system info is:
Rhino 7 SR11 2021-10-12 (Rhino 7, 7.11.21285.13001, Git hash:master @ ca75d3c67ded62b7ad8856f48d5ef2d6d1d926be)
License type: Commercial, build 2021-10-12
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 48Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD FirePro W4100 (AMD) Memory: 2GB, Driver date: 4-5-2021 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.Q1.2 27.20.14540.4003
> Accelerated graphics device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 4-5-2021
Driver Version: 27.20.14540.4003
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.11.21285.13001
Hi Dwight - does this happen regardless of what file, if any, is opened?
it’s inconsistent, it happens on different files but the one file I am working on freezes the system everytime
Hi Dwight - can you please send that file to tech@mcneel.com, with a link back to this topic in your comments?
it’s a 56 Mb file I don’t know if it will email?
Hello- use www.rhino3d.com/upload. Thanks.
uploaded the file
Thanks - your file opens fine here, I do not, so far, see anything amiss with it - some not-very-nice surfaces in the blocks but so far all valid and fine. I’ve purged some un-used blocks and saved - I’ll send it back, though it is a shot in the dark that that would help…
Thanks Pascal
I worked on the cleaned up file for hours without a freeze … thank you!
Can you please describe what you did to clean up the file?
Thanks
Dwight
Hi Dwight - I purged some unused block definitions - Purge command. Reamins to be seen why that halped and which block(s) was the bad one.
