Hi, is there a way to apply a window recess, typically 15mm on each side in the horisontal section drawings, this would really save time when exporting drawings and adding measurement. See attached example.
And then next question, is it possible to program all the layers in the wall but put them on an invisible layer when you create a horisontal/vertical section?
