Is there a way to ‘control’ which Gh plugins would be used and which would be ‘left off’?
(*Having a loaded amount, and always increasing, opening Gh is sometimes quite slow, without knowing what the problem is).
—I know the “Rhino—Tools-Plugins Loaded and Derived” window—
…but it doesn’t seem possible to control all the loaded plugins from there!…,
many of them will not appear in any of the windows there, in the different options——.
What is the best way to activate_deactivate_control Gh plugins?
I believe that there is the “Package-Manager”,–which allows you to install, update or uninstall one or another plugin–,
but I understand that it should have a New or “added” Option, where one will select which “Plugins they want to use” in what is going to be done.
(It’s almost ridiculous to see the number of plugins one can have in the top Window,
and then each letter being smaller by the quantity,
One must then look to see if the letter ‘d’ is from dendro, or from dixi, or from daniel, or from dora, etc.
-Even so, the worst problem is when it takes a long time to open gh!!.
–**I have sent it to Rhino support, more than once, but I don’t think if they understood or were interested in my question, to answer it clearly.
—I think something must exist, but I don’t know where to find it.
Finally, there would be a window of plugins installed in gh, and being able to activate the ones that one would use, or leave the favorites.
(I’m not a programmer).
Thank you
Greetings
