I am working on a project where I am parameterizing wind turbine segments. I am having issues the skin (external and internal) a thickness to be solid (parametric slider).
I have tried what you explained but it does not work. I am not sure whther if my workflow is correct. When I start increasing the number of segment my offset surface is giving a mistake.
With the individual lofts, the segments need to be joined first. Just like I wrote above. Of course if the input curves are not in pairs but four sorted circles, a single loft is sufficient.
I am kind of beginner with grasshopper so I was trying to perform with chat gpt a bit. Trying to make sure oututs and the like.
I used shift list to create segments (and use loft per segments) and also creates top and bottom per segment. I dont know how could this be part of the problem
I’ve tries tis in this script. the things is I need to create a truss panel inside and algo give the same thickness. but somehow did not work. I skipped the thickness and try to create all planar surfaces. Those are the two problems I am mainly struggling with
