Regarding the wind factors component, once I get a denser simulation test points grid, it delivers a warning saying it won’t be able to calculate the wind factors due to the excessive number of test points (grid size is set to 3m and my simulation parameters are in the image below). I was wondering if there is an option to make the Wind Factors run regardless of the dense simulation grid in order to get the Pedestrian Wind Comfort mesh.
One option I tried and shows a proper pedestrian comfort mesh (but I’m not sure if it is showing correct results), is to make a less dense simulation and run the Wind Factor component. Then the results will be somehow ‘stored’ in the Wind Factors component and when you simulate again with a denser grid you successfully get the Pedestrian Wind Comfort mesh.
Any piece of advice will be very well received!
Many thanks in advance,
Eliseo
