Will it fall- gravity simulation
Hey,
I am a new user of Grashopper. I would like to ask You If maybe You know how to check using Grashopper, weather this element will be stable and will not fall down?
Cheers,
Jan
will_it_stand.3dm (1.5 MB)
I would approach this by first making each part a single closed solid, then check whether the centre of mass lies within the triangle formed by the points where it touches the ground.
If the blue and red parts are not joined, you’d need to also check that the centre of mass of the top part is within its support on the bottom one.
