Hello, I found a grasshopper script that creates a voronoi pattern on unique surfaces. (Link is here: https://www.youtube.com/watch?v=YDFofhlWNxs). I tweaked it a bit to add rounded corners to the Voronoi holes, but otherwise it should be just like the video laid out. It worked great with the tutorial surface, and I was able to bake the final shape and use it as I chose in Rhino. I tried to use the algorithm on half of a leaf shape, and although it pushed my computer a bit, it created the Voronoi pattern just fine; however, it will not let me bake it. Every time I tried, the computer went to work, but when it was finished, there was no baked part. Just the “red” version that Grasshopper shows. My first few attempts were on a lofted surface, and I thought the compound surface curves might be causing the issue, so I remade the shape with simple bends in a single plane. No luck though.
Can anyone tell me why this won’t bake? It is not nearly as complicated as the tutorial shape so I’m confused.
I’ve included the Grasshopper file, and the shape that I’m adding the voronoi to should be internalized into the file.
Yes, that was the original shape from the tutorial, and I did not have any trouble baking that one either. The leaf shape that was internalized into the first Grasshopper file, however, does not bake. And it is a much simpler shape.
Edit: As a follow-up, the computer doesn’t even try to bake it. It’s not like the computer starts chugging away and then nothing materializes; just nothing happens. It does highlight green though with you click on the last step in the script.
I do not know how to solve this, but is seems to me that the input surface you have is the problem. It only has 3 edges and does not look like a rectangle at all.
Try different surfaces, closer to rectangle and see if you have the same problem again.
TIP: When experimenting only change 1 parameter at the time, otherwise you have no clue where to search when something is wrong.
Ok, so when you mentioned that it only had three sides, I had an idea and tried something. I put a small flat edge on the “Heel” of the shape, thus giving it 4 sides. After that, it allowed me to bake the finished result! As we now know, it obviously needs 4 sides to work. Thank you very much for taking the time to help me troubleshoot this! I really appreciate it.
