Why the script doesn't work?
1.gh (7.6 KB)
You need to set the "x’ input to List access and your type hint to either Integer or Float - then it will work, otherwise it thinks that the “1” in your list is a string and 1 as a string != 1 as an integer.
Also, you can make it much more compact with a list comprehension
I’m self taught and I have this script in a definition.
Unless you plan to extend your script, I don’t think there’s a benefit of having a loop…
Right click on the ‘x’ input
