Why the change of material UI
Hello, i was used to the latest material selection window, it was so easy to navigate, then i get that the material window is so confusing, is there a way to go back to the amazing material selection/edit window for the last version?
CONS: There is no way to drag a material from the library to the material tab, if i want to select a material from the library, i have to assign it firs to a part and then i can edit it, if i want to search one material (from the material tab) i don’t have a visual reference of the material i’m picking. it is quite confusing
