Why saving time for a 2,4GB file is same on HDD and SSD?
Years ago I noticed that saving the Rhino files on an SSD is not faster, but I thought that it may be related to the small file size. However, now that I have a 2,4 GB large file that takes way too long to save on my HDD, I decided to move it to my system drive (SATA 3 SSD Samsung 860 Evo), but Rhino is still too slow when it comes to saving. I measured nearly identical times for saving exactly the same file, both, on my HDD and my SSD. I wonder, if the CPU (Intel Core-i5 4460) causes the bottleneck, rather than the type of drive where the Rhino file is being stored? I also use 16 GB (4x4) DDR3 memory.
In Options>Advanced, turn off file compression when saving.
Does that mean that the file size will increase when compression is turned off? Also, is the CPU used to compress the saved file? If so, looks like a new CPU with plenty of cores will help a lot? :slight_smile:
Edit: I just did a test with the file in question, and your suggestion helped to cut the file saving time more than twice at the expense of some extra storage space. Thanks a lot! :slight_smile:
Compession on: 75 seconds to save, file size is 2409 MB.
Compression off: 30 seconds to save, file size is 2724 MB.
Your CPU is from 2014. The everything is the bottleneck. You should have like 128GB RAM for working on 2GB+ files, how much virtual memory are you using?
It’s set to “System managed size” and is currently 2935 MB. The memory utilization of Rhino 7 while I work on that particular file is never above 9 GB RAM. Performance is great, it’s the slow saving and autosaving that takes a huge time despite using an SSD.
Hi Bobi, when you say “ a huge amount of time”, is that 10 minutes?—-Mark
No, I mean more than a minute. :slight_smile: As I mentioned in an earlier post, saving to my SSD with compression turned off takes whole 75 seconds for a 2,4 GB file. Saving the same file on my HDD takes 81 seconds, which is a negligible difference, considering that my SSD should be approximately 4-6 times faster.
