Why Populate Geometry so slow?
My code is a good code :smiley: always.
The dictionary that have sequential numbers starting from 0 as its keys is used to make the merge after a parallel computation easier.
What the code is doing is,
  1. compute a ā€œcomfortableā€ distance between points
  2. divide the region by cells whose edge is the comfortable distance and store each point in each cell.
    3 Create point-> cell and cell->point data structure (done by dictionary)
  3. compute forces between the points, but only points in adjacent cells are computed.
  4. update the positions by looking at the forces.
    (repeat 20 times)
I rewrote the code in C# and it became 10x faster!!
500pts 0.37s
5000pts 1.9s
50000pts 25.5s
500000pts 5.3m
sampling_C#.gh (6.2 KB)
The algorithm was slightly improved especially around the boundary edge.
I’m not familiar with parallel in Python. But at least you don’t quite need to handle it manually in C#. Let me go through your code and make it faster.
Oh, yes please!
Slightly faster. still much room for improvement. Curve operations are definitely bottlenecks.
protected override void SolveInstance(IGH_DataAccess DA)
            unchecked
                Curve crv = null;
                var N = 0;
                var iteration = 20;
                DA.GetData(0, ref crv);
                DA.GetData(1, ref N);
                DA.GetData(2, ref iteration);
                var sw = new Stopwatch();
                sw.Start();
                var srf = Brep.CreatePlanarBreps(crv, 0.0001)[0];
                var rnd = new System.Random();
                var face = srf.Faces[0];
                var domU = face.Domain(0);
                int ss = 100;
                var AM = AreaMassProperties.Compute(srf);
                var area = AM.Area;
                double dd = Math.Sqrt(area / (N * ss));
                ee = Math.Sqrt(area / ((double)N) * 4d / Math.Sqrt(3d)) * 1.1d;
                int NN = (int)(Math.Sqrt(N * ss));
                var pts = new List<Point3d>();
                _crv = crv;
                for (var i = 0; i < NN; i++)
                    double t = ((double)i) / ((double)NN);
                    double u = domU[0] + (domU[1] - domU[0]) * t;
                    var cc = face.TrimAwareIsoCurve(1, u);
                    for (var j = 0; j < cc.Length; j++)
                        var ccc = cc[j];
                        double L = ccc.GetLength();
                        int NNN = (int)(L / dd);
                        if (NNN > 0)
                            pts.AddRange(ccc.DivideByCount(NNN, false).Select(ccc.PointAt));
                ppp = pts.OrderBy(x => rnd.NextDouble()).Take(N).ToArray();
                dict1 = new Dictionary<(int, int), List<Point3d>>();
                dict2 = new (int, int)[N];
                for (var i = 0; i < N; i++)
                    var p = ppp[i];
                    int xx = (int)Math.Floor(p.X / ee);
                    int yy = (int)Math.Floor(p.Y / ee);
                    var key = (xx, yy);
                    if (dict1.TryGetValue(key, out var list))
                        list.Add(p);
                    else
                        dict1[key] = new List<Point3d>() { p };
                    dict2[i] = key;
                var boundary = new Dictionary<(int, int), bool>();
                foreach (var key in dict1.Keys)
                    boundary[key] = test(key.Item1, key.Item2);
                for (var t = 0; t < iteration; t++)
                    var dict3 = ParallelEnumerable.Range(0, N).AsOrdered().Select(F1).ToArray();
                        var V = dict3[i];
                        var p = ppp[i];
                        var key = dict2[i];
                        dict1[key].Remove(p);
                        Point3d newp = p + V * 0.7;
                        if (boundary[key])
                            var PC = _crv.Contains(newp, Plane.WorldXY, 0.0001);
                            if (PC == PointContainment.Inside)
                                ppp[i] = newp;
                            else
                                double tt;
                                _crv.ClosestPoint(p, out tt, 1000);
                                var T = _crv.TangentAt(tt);
                                T = new Vector3d(T.Y, -T.X, 0);
                                T.Unitize();
                                V -= (T * V) * T;
                                newp = p + V * 0.7;
                                ppp[i] = newp;
                        else
                            ppp[i] = newp;
                        int xx = (int)Math.Floor(newp.X / ee);
                        int yy = (int)Math.Floor(newp.Y / ee);
                        key = (xx, yy);
                            list.Add(newp);
                        else
                            dict1[key] = new List<Point3d>() { newp };
                        dict2[i] = key;
                    foreach (var _key in dict1.Keys)
                        if (!boundary.ContainsKey(_key))
                            boundary[_key] = test(_key.Item1, _key.Item2);
                sw.Stop();
                DA.SetDataList(0, ppp);
                DA.SetData(1, sw.ElapsedMilliseconds);
        Point3d[] ppp;
        Curve _crv;
        Dictionary<(int, int), List<Point3d>> dict1;
        (int, int)[] dict2;
        double ee;
        static readonly int[] jjj = new[] { 0, -1, 1 };
        private bool test(int xx, int yy)
            unchecked
                double minx = (double)(xx) * (ee);
                double maxx = (double)(xx + 1) * (ee);
                double miny = (double)(yy) * (ee);
                double maxy = (double)(yy + 1) * (ee);
                var P = new Point3d(minx, miny, 0);
                var Q = new Point3d(maxx, miny, 0);
                var R = new Point3d(maxx, maxy, 0);
                var W = new Point3d(minx, maxy, 0);
                return _crv.Contains(P, Plane.WorldXY) != PointContainment.Inside
                    || _crv.Contains(Q, Plane.WorldXY) != PointContainment.Inside
                    || _crv.Contains(R, Plane.WorldXY) != PointContainment.Inside
                    || _crv.Contains(W, Plane.WorldXY) != PointContainment.Inside;
        Vector3d F1(int i)
            unchecked
                var p = ppp[i];
                var key = dict2[i];
                var xx = key.Item1;
                var yy = key.Item2;
                var V = Vector3d.Zero;
                for (var iu = 0; iu < 3; iu++)
                    for (var iv = 0; iv < 3; iv++)
                        var u = jjj[iu];
                        var v = jjj[iv];
                        key = (xx + u, yy + v);
                        if (dict1.TryGetValue(key, out var cell))
                            for (var ii = 0; ii < cell.Count; ii++)
                                var q = cell[ii];
                                var dist = (p.DistanceTo(q));
                                if (dist <= ee)
                                    var L = 1 - dist / ee;
                                    V += (p - q) * (L * L);
                return V;
Thanks gankeyu! This very helpful.
It seems like I need to learn LINQ more. I didn’t know even Take().
Btw, I guess this syntax is very new. Don’t know if it works in C# node inside GH…
And, heeey! What’s this syntax!? This is Python tuple… Didn’t know recent C# has it!
It’s ValueTuple. Compared to Tuple, it’s about 50% faster when used as a Dictionary key. I don’t think GH’s C# supports it.
Nope. You would need:
List<Point3d> list = null;
if (dict1.TryGetValue(key, out list))
Thank you! Thank you! I’ve been away from C# for a couple of years.
I’ve been using Python because writing is faster than C#. But obviously performance is not…
Is there somebody out there in McNeil who want to buy this code?
500pts 0.37s
5000pts 1.9s
50000pts 25.5s
500000pts 5.3m
How about $10? :slight_smile:
David Rutten is doing Poisson Sampling for GH2 so I am not sure McNeel need another one
Joke, it was a joke. Looking forward way powerful GH2!
Don’t underestimate your job, I am sure GH2 will brings efficient algorithms, but sometimes there are some lacks that are taken by plugin (offset …). So if you have made good improvements to your script publish it on this forum and food4rhino.
I think also populate 3D geometry (you have done 2D populate) could use Heat Method from Keenan Crane …
What algorithm(s) did you use to get such results?
I attached a human-readable code and the strategy already :unamused: But thanks for having interest.
I would remind again that the goal is to achieve O(N). Not to make the code only faster.
The key point in the algorithm is if you divide the region to the cells, there are only one, or two, or maybe three points in a cell. The number of points in a cell cannot go high even if you increase the number of points.
So if you compute the forces between points that are only in the adjacent cells, the total amount of computation is nearly proportional to N.
Sorry, I must have skipped that somehow.
Sounds similar to the Poisson disc sampling algorithm.
You could try switching from Dictionary to HashSet. Lookup goes from O(log n) to O(1) in that case. And I think in the newer HashSets it’s now possible to retrieve an entire value stored in the set if you find a colliding key. This wasn’t possible before making HashSet a lot less useful.
On the other hand, it seems you’re creating points everywhere within some boundary, so why not just store your points directly in an array? Or am I mistaken in believing this array would not be particularly sparse?
Hi David! Thanks for popping out!
I simply didn’t know HashSet. I’ll check it out. Thank you.
I assume your ā€œarrayā€ is an array of the cells. The reason I’m using dictionary instead of a static array is, simply I was not able to come up a good strategy to cover an arbitrary region by cells.
Theoretically the initial points may be covering the entire region almost perfectly. So the cells computed from the points may cover the region perfectly. But there is a chance there are some missing cells, and when points move to those missing cells, we need to add a cell. If you want to avoid this, you need to compute the cells without the help of the distributed points but only by looking at the boundary curve. I simply didn’t come up any idea…
Are you sure about this? I for instance know that in Python dictionary lookups are also O(1), though sets are also considered a little faster still for different reasons, maybe because there is no referenced data?
Absolutely, I for instance stored the points in a one-dimensional array, which is faster and cheaper than multi-dimensional ones, when I implemented Poisson disc sampling for a project of mine. You can still easily loop through it with a two-dimensional row-column-logic, like so:
#include <tuple>
int columns = 10;
int rows = 10;
// Array of pairs representing two-dimensional points
std::pair<double, double>[columns * rows] points;
for (int x = 0; x < columns; x++) {
  for (int y = 0; y < rows; y++) {
    points[x + y * columns] = std::make_pair(x, y);
I guess you don’t even need ā€œrealā€ cells, when each position in a one-dimensional array is simply considered to stand for a cell. If you for instance only allow one point per cell, a vacant cell could empty - it’s position in the array would be NULL, None, -1, or whatever -, whereas occupied cells would be defined by simply a point at that index in the array.
If you have a non-rectangular region, you could for instance test not only if the new point is in a free cell, and at a tolerated distance from neighbouring points, but whether it is contained within the region in question. The grid could be simply a rectangular grid filling the bounding rectangle of the region, if that makes sense.
Here’s a real-time demo of my Poisson implementation creating 7,300 points in a 400 by 400 unit region:
It’s somewhat slower than yours, but I haven’t optimised it.
Though I agree dynamic generation of cells is not the best idea, this animation explains well the algorithm.
