I wrote a wrapper class for a C++ library written by David Coeurjolly which refactors a low disc blue noise point sampling algorithm. The algorithm is based of this paper. The gist is that the blue noise component that I wrote can create an even distribution of 5,000,000 points in 2.1 seconds. The source code for this can be found here.
For those that want to skip the source code, you can test this component out by copying these two files (see zip file) into your components library.
Blue Noise Point Generator.zip (131.8 KB)
