offsetround.3dm (736.4 KB)
I don’t understand this behavior. How should I prevent this?
I attached the surface. Thanks!
Hi @Bogdan_Chipara,
'a bummer your question got skipped.
I wouldn’t be able to answer on behalf of mcneel, meaning my answer is potentially false, but it seems the offsetcrvonsrf command has a bug or lacks configuration (sharp vs round corners, like the regular offset).
Anyway, you probably solved it already, but if you simply use the plain ‘offset’ command, it works:
Best
Hi @corellaman,
I was pointing this out because i bump into this bug or lack of configuration too many times. So i narrowed it down juts to have a clear example of the problem. Would be good if McNeel would look into it.
Yes, pain offset works.
Best!
