Why naked edges in this sweep on helix?
V5
I have been oh so careful. drawn the thread profile dark blue.
drawn the helix with correct pitch entered as a number and dragged out radius to snap to profile tip.
drawn a second helix to act as second rail, as one rail saw wierd effects.
sweep2
and result has naked edges.
Not sure how to fix them.
the profile is a perfect match to all the theoretical lines for the thread.
help !
I then intend to trim the ends with the two sheets.
Its a boolean difference cutter and no need to have the thread feather in as a bolt would have.
2BA Female Thread naked edge.3dm (3.6 MB)
I try for a single ‘lap’ then copy move it, run intersect, and its not quite complete, but why ?
2BA Female Thread naked edge try suss.3dm (577.4 KB)
what is wrong with the helix command ?
Steve
Nothing
Solution:
Split the thread surface using the outer helix curve
Join the two parts
Result is a single polysurface with not internal naked edges
Hi David,
Many Thanks.
Thats solved it.
Why was it that there was a naked edge there ?
Steve
The cause appears to be: an edge of an object cannot be joined to an edge of the same object.
