Hi, I’m new to Rhino so I’m still learning about the program, but in this project, the texture of the material is in a really bad quality when I render it, even though I render in the maximum quality. I don’t know if this can be related, but I used the ‘‘CAP’’ tool to close the form. Does anyone know what I can do?
the texture is too big. you have to improve the mapping which is the way that the texture is applied on the object
Change the texture repeat value for the material in the Materials panel. By default all library materials will use what is called WCS mapping (world coordinate system) which means the image texture in the model is set to a certain real world size. Your model can also be scaled to change the size of the texture.
