i am pretty sure i turn the autoreset off.
i relocate the gumball, here is the result
and i click it again, i got this.
anyone could help me? thanks a lot
(my rhino version is Rhino 6, 6.4.18124.12321)
Hello - if that is not one object but a group, that is the expected and currently the only possible behavior. You can Block
the objects to make it one top level object and the gumball should stick.
thanks a lot!!!
really helpful!!!
can’t appreciate more!!!
Adding to this old thread.
Relocating the Gumball on an object, then copying it using Gumball + alt, doesn’t preserve the location of the gumball on the original. For better user experience, I think the default action should retain the same location on the copy.
Thanks!
