Hello everyone, everytime I print to pdf, the lines get way thinner than what is shown on detail. Why this happens??
Can you post a file that shows this behavior?
is too heavy
Is it only the heavy file that does this? Can you copy a few of the lines to another file and see if it has the same problem/share it if it does?
they are not really lines, is a sectioned model. There is no lines or curves in the images.
Hi Leo -
From that image, it looks like you are printing to raster pdf. You could try changing the dpi and/or page size to somewhat change the thickness of those curves.
Also, when large objects are also in the scene (but only partly visible), it can help hiding those when printing.
The alternative is copying the viewport to an image file and placing that on a layout.
If you can post or upload a file we can see the all the variables.
One thing you can quickly bump the line weight is via Scale
thanks, it made it!
