And what can I do? How would you approch this?
thx!
rhinoquestion.3dm (433.3 KB)
you may want to adjust your topology with some well placed splits by isoparam and then shrink the trimmed surfaces to be able to do some matching.
I’d suggest something like this.
if this is a critical part where reflections are paramount, you may want to go back and rebuild all your curves to match points counts and degree so you can make this all single span.
the curves you are building from are pretty heavy and the point count is all over the place. Remember, the simpler your curves the cleaner your surfaces.
