I can see that there is a gap with turning on showedges but I can’t figure out how to solve this… What sould I do?
csavartcsésze.3dm (785.8 KB)
Hello - there is a bit to do here - if you look closely at the top edges, you’ll see there is a problem at each surface seam on the inside:
I think you must have used OffsetSrf
, possibly?
If so, you need to clen up your outer surfaces first and make those transitions truly tangent to the larger faces - then offsetting has a chance of making the right thing.
these guys need to be tangent.
One way to do this from what youve got now is to RebuildUV
these surfaces in V with 4 points
Then MatchSrf
them for tangency only, match by closest points, preserve isocurve direction.
Like so:
csavartcsésze_BetterSurfaces.3dm (427.0 KB)
Then, Join and offset.
See help on the above commands if they are new to you.
Yes, I used OffsetSrf , would there be a better was to do this?
I am quite new in using rhino
It also looks like you chose the wrong template when you started the model.
I think you would be better off with Small Objects - Millimeters considering the size of your model.
Thank you for your help!
