Why is only part of my extrusion mapped with the orient command?
why is only part of my extrusion mapped with the orient command?
Skript_Orient_Problem.gh (29.0 KB)
I guess there’s something off with your tree:
How can I solve this?
short and easy answer:
If you want the entire list of geometries oriented for each plane, you have to flatten the extrusion tree The error however comes from a bit before, when you graft the points:
a single point and a list of points already handle each one separately. I think you confused with polyline. by grafting you produce duplicates and mess up the tree structure.
Skript_Orient_Problem_BDE.gh (21.3 KB)
it’s crucial you have a look at how tree structures work in grasshopper:
hope this helps
Ben
