Why is boolean union not working with these surfaces?
help appreciated!
help needed boolean union.3dm (19.3 MB)
If you set a clipping plane, you can see why. The geometry is not touching or intersecting itself at some points.
Also, at the bottom, there is a missing part of the surface.
Once these two were connected, the join worked. (However, there are still a couple of issues with your 3D model.)
help needed boolean union_1.3dm (19.0 MB)
As mentioned in the other thread, you first need to make a proper model. There are many beginner tutorials on Rhino’s website or on YouTube. In essence, good curves > good primary surfaces > good secondary surfaces > good fillets and other detailing.
thank you so much!
