1.3dm (35.0 KB)
tell us what you exactly want to achieve - or play around with many of the commands you find here:
_extrudeCrv
_loft
_sweep1
_sweep2
_srfPt
_boundinbox + explode + delete
… will be possible to get the surfaces from my screenshot
THANK YOU FOR YOUR REPLY
ACUALLY I DONT WANT TO USE BOOLEAN UNION AND MERGE ALLPLANNAR SURFACE OR JOIN ALL THE TIME
- I JUST WANT TO SAVE TIME IN MODELLING @Tom_P
PLEASE don’t post in all caps.
If you create two rectangular curves and PlannarSrf them together, it does create two separate surfaces
although at this point it is easier to directly make rectangular surfaces
or make a box and remove what you don’t need, but that wasn’t what you asked.
thanks @eleven @M_Thorez @Helvetosaur
good idea but is not fulfil different type of crv. like below @eleven
anyway, i need to use join or Boolean and mergeallcoplannar. @M_Thorez
_ the point is i want srf withno extra command like Boolean or join i think. by the time i guess is not possible?
_ can you suggestion any YouTube channel for making furniture and interior design
I really do not see the point of optimizing here as it is already only two actions: select all curves, make them become planes all at once, then join everything in one command. I genuinely do not see how you could make it simpler
maybe if you working with, like, hundred of surfaces it could be worth it to create a grasshopper script, but otherwise it is already a pretty simple set of actions
Quickest way of doing this - unless your lines exist - is to directly draw your planar surfaces, move the one that needs moving on the z-axis then extrude vertically the edge of the bottom surface to meet the top one. (takes longer to type than do!
) Sorry. no specific references to tutorials.
You can also gumball extrude surface edges…
If you need to make a lot of connected rectangular planar surfaces then, as Tom says, use gumball extrude. Create a polyline representing one set of edges and extrude it to make multiple connected surfaces in one operation:
thanks @jeremy5
