I want to fillet the edges, but to be continuos and not to make copies of the fillets.
This is what I got: filletedge.3dm (616.2 KB)
Thanks¬!
Thanks¬!
you’re telling it to do things which aren’t geometrically possible… for instance:
if you tried to draw that manually, you’d be able to see why it’s failing…
if you use a fillet radius of .025 on your model, it will succeed:
hi
if your fillet radii are important that you must do exactly, you may do a step by step approach as in the file.
filletedge_blastered.3dm (376.4 KB)
