Why doesn't everything move when I drag?
I’ve had this problem before but this time it is rather more important. Sometimes when I drag the cursor over a thing to select it, and then use the gumball to move it, not all the things that were selected get moved. In this example file, when I select everything, then try to drag it to the right, the annotations for curve length do not move even though they stay selected. Why?
CurvedStairs-260409.3dm (1.8 MB)
I’m working in Rhino8, Win11
Rhino 8 SR34 2026-8-11 (Rhino 8, 8.34.26223.11001, Git hash:master @ f416e902495235e4e4a45cfc29ff1320cc8c70d8)
License type: Commercial, build 2026-08-11
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.28
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 1-20-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.86
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port 0
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 1-11-2024 (M-D-Y).
Accelerated graphics device with 5 adapter port(s)
  • There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-20-2026
Driver Version: 32.0.15.9186
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\Jozef\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\1.0.8405.22062\TeDaSharp_060.rhp “TeDAsharp” 1.0.8405.22062
C:\Users\Jozef\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ObjectOutliner\0.9.2\net7.0\ObjectOutliner.rhp “ObjectOutliner” 0.9.2.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
Hi Joe -
I see that happening with those three leaders in your file, but when I try to make a new such leader, this one behaves as it should.
Is there a way to make it so that a leader doesn’t follow along when moved?
sorry, I don’t understand.. I want the leaders to move. When I select all, I expect everything to move.
looks like you could update a driver that will help in other things.—Mark
Hi Joe -
I understand that. This is clearly not working as it should.
To be able to fix it, though, we need a way to get a leader to start behaving like that.
In your file, when I place a new leader with DimCurveLength, that new leader behaves as it should.
If you know of a way to “break” a leader like the ones in your file, please let us know.
Updated NVidia driver. No change in problem.
FWIW, I cannot reproduce the problem - everything moves, every time. Suggesting there is something system specific about the issue. An obvious difference is that I don’t have your two non-Rhino plugins - does temporarily disabling them make a difference?
Disabled them both. Made no difference.
Hi Jeremy -
That is the behavior I get only when I disable the history “Update Children” setting.
@Joe4 - I take it that this is not something that you can reproduce in a new file?
Not able to reproduce it intentionally. But… I disabled “Update Children” and the problem seems to go away in this particular case. I’ll remember that in future. Not sure what “update children” does but if it works, it works.
thanks.
I really, really wish all history objects had a pivot point that could be manipulated and settings that could be tweaked.
It would finally make history usable for more complex modelling.
It’s one of the many things that is halfly implemented, robust but not very editable or user friendly, rendering it useless in too many situations.
Holo makes a great point.
I’ve also been waiting and wishing for this and post about it every new version of Rhino. In my opinion this is the one thing that is really holding back productivity and slowing me down. Great and thoughtful history without all the caveats it currently has will make rhino a more powerful tool.
RM
Hi Joe -
If you just need to make the problem go away, you can use the HistoryPurge command on objects that have issues with updating their history records.
Now how am I supposed to know if there is an issue with history records? I did not have record history on during any of this. Is there a command that can tell me what history exists for any particular thing? I got no error message when trying to move those things.
Hi Joe -
When you move all object, the dynamic preview looks right. When the move finishes, those three objects hop back to their original position.
By default, history is always on for annotations. You can turn this off by running the dashed version of history: -History and change the RecordAnnotationHistory option to No.
You can use the SelObjectsWithHistory command to identify which objects have history records attached to them.
This is clearly a bug, but until we find a way to reproduce it, it won’t get fixed.
I suspect that the fact that history for annotations is always on is part of the source. One of the problems I have had in the past is selecting a bunch of things, moving them, and having some of the annotations move and others don’t but what happens is the extension lines stretch leaving the dimension where it was. Seems like this should be a clue about the bug.
