Why doesn´t work GetScriptObject in this plug-in?
This plug-in works properly until the command Rhino.islayervisible(strLayer). Anyone know why could be this? I am developing this plug-in with VB in Visual Studio 2015.
You can see my program below:
Imports System
Imports System.Collections.Generic
Imports Rhino
Imports Rhino.Commands
Imports Rhino.DocObjects
Imports Rhino.Geometry
Imports Rhino.Input
Imports Rhino.Input.Custom
Namespace ACTIVAR_CAPAS
<System.Runtime.InteropServices.Guid("c1135058-446c-4002-bae0-3aa90b39e42b"),
Rhino.Commands.CommandStyle(Rhino.Commands.Style.ScriptRunner)>
Public Class INCOMACTIVARCAPASCommand
    Inherits Rhino.Commands.Command
    Shared _instance As INCOMACTIVARCAPASCommand
    '''<returns>The command name as it appears on the Rhino command line.</returns>
    Public Overrides ReadOnly Property EnglishName() As String
        Get
            Return "INCOMACTIVARCAPAS"
        End Get
    End Property
    Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As RunMode) As Result
        Dim Rhino, objRhinoScript As Object
        objRhinoScript = CreateObject("Rhino5x64.Interface")
        If (Err.Number <> 0) Then
            RhinoApp.WriteLine("Unable to create Rhino5x64.Interface object")
            Exit Function
        End If
        Rhino = objRhinoScript.GetScriptObject
        If (Rhino Is Nothing) Then
            RhinoApp.WriteLine("Failed to get Rhinoscript object")
            Exit Function
        Else
            RhinoApp.WriteLine("Rhino object created.")
        End If
        Dim arrLayers As Array
        Dim strLayer As String
        arrLayers = Rhino.LayerNames
        If IsArray(arrLayers) Then
            For Each strLayer In arrLayers
                If Rhino.islayervisible(strLayer) = False Then
                    Rhino.layervisible(strLayer, True)
                End If
            Next
        End If
        Rhino = Nothing
        objRhinoScript = Nothing
        Return Result.Success
    End Function
End Class
End Namespace
Hi @javiervg84,
When writing .NET plug-ins for Rhino, you will be using the RhinoCommon API, not RhinoScript.
– Dale
Hi dale,
I know that but I´d like to use rhinoscript because is easier for me. Do you know any tutorial to learn rhinocommon?
Thank you.
Hi @javiervg84,
You can begin to learn more about RhinoCommon here:
And, there are lots of code samples on our GitHub site:
– Dale
